MOTOR BOXER 6 CILINDROS
+8
12 participantes
Conheçam o motor boxer 6 cc da subaru, talvez ele seja bem mais fácil de adaptar num buggy que um motor ap, com isso teriamos potência de sobra além de um barulho agradável pois ele não tem eixo de comando e sim correia dentada além de existir com as versões 2, 4 e 6 cc 2.0, 2.5, e 3.0, também dispõe das versões diesel e gasolina.
http://t2.gstatic.com/images?q=tbn:ANd9GcSGhevi4XGmz2M3Iba10WWGohuzDRAEVBrr8ur48OTyWr7TmlnU-w
http://t1.gstatic.com/images?q=tbn:ANd9GcQQ_qT8xpYY_ZQHyTtKDuSxZYlZLZgqAWWnCrUbVk85ueX2dLYg
http://t3.gstatic.com/images?q=tbn:ANd9GcTwWeynIkUikFWr0whDUuqjSR_aswaXeGSaZs6V2waHjkPCqeky0A
http://www.google.com/imgres?imgurl=http://www.instablogsimages.com/images/2008/04/16/volks-bus-3_7071.jpg&imgrefurl=http://www.automotto.com/entry/volkswagen-bus-powered-by-a-subaru/&usg=__Af3NzuQYE0k0FGPrCDo3Yy2G01o=&h=413&w=550&sz=52&hl=pt-BR&start=4&zoom=1&tbnid=LD4JM8LXk6p1cM:&tbnh=100&tbnw=133&ei=N1CPTYayN6OV0QHXndyrCw&prev=/images%3Fq%3Dmotor%2Bboxer%2Bsubaru%26um%3D1%26hl%3Dpt-BR%26sa%3DX%26biw%3D800%26bih%3D485%26tbs%3Disch:1&um=1&itbs=1
http://www.google.com/imgres?imgurl=http://3.bp.blogspot.com/_4N79G1oH89E/SHIFt9OTLhI/AAAAAAAABas/qHjy9wO9ads/s320/Luso_Motors_001.jpg&imgrefurl=http://www.4rodas1volante.com/2008/07/tugas-todo-o-gs.html&usg=__VIJcEHOuMTwRt5Of27zaw8IxYBY=&h=240&w=320&sz=23&hl=pt-BR&start=2&zoom=1&tbnid=W3Ow39WimYGmjM:&tbnh=89&tbnw=118&ei=eFCPTeG-HKbk0gHVubmlCw&prev=/images%3Fq%3Dmotor%2Bboxer%2Bsubaru%26um%3D1%26hl%3Dpt-BR%26sa%3DX%26biw%3D800%26bih%3D485%26tbs%3Disch:1&um=1&itbs=1
http://t3.gstatic.com/images?q=tbn:ANd9GcRqx4rL15WZsjQXgVWbGsyKJivSFVrHrBFBafvtauJFhpf724F1MQ
http://t2.gstatic.com/images?q=tbn:ANd9GcSRRjuyB4TwKQe4ivDTM_TEA_D3RIw3wkZfHWjL61kKUY9UVmAe
http://t2.gstatic.com/images?q=tbn:ANd9GcQZX_9WeIM6quQkK6d32AzvhV18AzKIHScXBcXRV85zXkPp9bFW
http://www.google.com/imgres?imgurl=http://www.subaru.pt/lineup/legacy/sedan/technology/imgs/boxer_engine.jpg&imgrefurl=http://www.subaru.pt/lineup/legacy/sedan/technology/index.asp&usg=__wMJjZHzJ8D5h1HoZ738FqRDUdaI=&h=200&w=250&sz=12&hl=pt-BR&start=1&zoom=1&tbnid=VdpKr9Q0IlHoEM:&tbnh=89&tbnw=111&ei=7C6PTfyAFeaD0QHJ58XBCw&prev=/images%3Fq%3Dmotor%2Bboxer%2Bsubaru%26um%3D1%26hl%3Dpt-BR%26sa%3DX%26biw%3D800%26bih%3D485%26tbs%3Disch:1&um=1&itbs=1
http://t3.gstatic.com/images?q=tbn:ANd9GcSIucQk_9y5FrT31ElBrirCFpflQ2uJHOCiQ4ICEqrLojZrxZPK_w
http://t1.gstatic.com/images?q=tbn:ANd9GcTrv7RMiYRqq5ARHMKKKCKYH6iJrbNnz0vDINMvX29HGSHgczaw
http://t0.gstatic.com/images?q=tbn:ANd9GcR2CoBIicOJD3PUwwJRxD0N8vQk4rh-m3XR4TekzMaVJcyIgsBcpgqng__Q5Q
http://www.google.com/imgres?imgurl=https://2img.net/r/ihimizer/img126/3925/bensrebuild020pw4.jpg&imgrefurl=http://forum.autohoje.com/forum-geral/58471-motor-deitado.html&usg=__dbE-TbAYc0HpPTFg2Vzp9v7KiNY=&h=600&w=800&sz=273&hl=pt-BR&start=2&zoom=1&tbnid=zu0HGyS2Y76P_M:&tbnh=107&tbnw=143&ei=ulCPTdHyCem90QGhtri9Cw&prev=/images%3Fq%3Dmotor%2Bboxer%2Bsubaru%26um%3D1%26hl%3Dpt-BR%26sa%3DX%26biw%3D800%26bih%3D485%26tbs%3Disch:1&um=1&itbs=1
http://t2.gstatic.com/images?q=tbn:ANd9GcSV2OUi5KSEGneKol8KQLzTx_JHGWYzeH1g-Os6t6QF0QsHPOBXAA
http://t0.gstatic.com/images?q=tbn:ANd9GcREG_bIh8Bnu7VJGAdMCqRPLVJVL4XkBvvlEhywcH9MOgma-QN_Aw
http://www.subaru.co.cr/images/inter/ventajas.jpg
Pontos : 11775
Re: MOTOR BOXER 6 CILINDROS
Evilasio escreveu:Conheçam o motor boxer 6 cc da subaru, talvez ele seja bem mais fácil de adaptar num buggy que um motor ap, com isso teriamos potência de sobra além de um barulho agradável pois ele não tem eixo de comando e sim correia dentada além de existir com as versões 2, 4 e 6 cc 2.0, 2.5, e 3.0, também dispõe das versões diesel e gasolina.
EVILÁSIO, ESSE É UM SONHO INATINGÍVEL DE QUEM GOSTA DE MOTOR BOXER. QUANDO PENSAMOS EM ADAPTAR UM MOTOR EM BUGGY, SÓ PODEMOS USAR O QUE SE TEM FÁCIL A MÃO. EU MESMO VIVO PROCURANDO UM SUBARU PRA RETIRAR O MOTOR E ATÉ HOJE NÃO CONSEGUI.
Pontos : 10127
, escreveu:Evilasio escreveu:Conheçam o motor boxer 6 cc da subaru, talvez ele seja bem mais fácil de adaptar num buggy que um motor ap, com isso teriamos potência de sobra além de um barulho agradável pois ele não tem eixo de comando e sim correia dentada além de existir com as versões 2, 4 e 6 cc 2.0, 2.5, e 3.0, também dispõe das versões diesel e gasolina.
Nil você já procurou em alguma seguradora?
Pontos : 11775
Para fazer um , uso próprio até dá. Gostei da idéia, já tinha visto deste em um desmanche mas faz tempo. Qual será o peso deste motor. A dificuldade seria a manutenção? A adaptação pro buggy dever ser facil, as fotos mostram este boxer em fuscas.
Pontos : 7598
O peso exato eu não sei mas por ser todo de alumínium certamente deve ser bem mais leve que um ap que tem o bloco de ferro.Volnei S escreveu:Para fazer um , uso próprio até dá. Gostei da idéia, já tinha visto deste em um desmanche mas faz tempo. Qual será o peso deste motor. A dificuldade seria a manutenção? A adaptação pro buggy dever ser facil, as fotos mostram este boxer em fuscas.
Pontos : 11775
Nil procura o Aroldo peças da Bezerra de Menezes que ele tem um excelente canal com todas as seguradoras e consegue qualquer peça original por um preço excelente e tu conversando com ele certamente ele consegue um motor desses pra ti.Evilasio escreveu:, escreveu:Evilasio escreveu:Conheçam o motor boxer 6 cc da subaru, talvez ele seja bem mais fácil de adaptar num buggy que um motor ap, com isso teriamos potência de sobra além de um barulho agradável pois ele não tem eixo de comando e sim correia dentada além de existir com as versões 2, 4 e 6 cc 2.0, 2.5, e 3.0, também dispõe das versões diesel e gasolina.
Pontos : 11775
Nil procura o Aroldo peças da Bezerra de Menezes que ele tem um excelente canal com todas as seguradoras e consegue qualquer peça original por um preço excelente e tu conversando com ele certamente ele consegue um motor desses pra ti.[/quote]Evilasio escreveu:
HE HE , O AROLDO É MEU VISINHO E COMPRO COM ELE DESDE OS TEMPOS DAS "VACAS MAGRAS"
NA VERDADE, QUERO COMPRAR UM NA "GARAPA" OU SEJA, COM PREÇO BOM. A IDEIA É APENAS MONTAR UM BRINQUEDINHO PRA BRINCAR NAS DUNAS. ALÉM DO MOTOR, O OUTRO DETALHE É O CAMBIO. NESSE MOMENTO, ESTOU MONTANDO UMA GAIOLA COM MOTOR 2.0 CENTRAL QUE VAI GANHAR UM TURBO E CAMBIO DO GOL MAS SE CONSEGUISSE UM SUBARU, JÁ COLOCARIA NELE. FIQUEI SABENDO DE UM IMPREZA ENFERRUJADO E AGUARDO O CONTATO PRA IR VE-LO.
GRANDE ABRAÇO.
Pontos : 10127
Fico na duvida, sei que o motor do subaru é bem melhor, mais moderno, mais economico, maissilencio etc.... Mas será que não vale mais a pena trabalhar num vw ar mesmo? Gastando o mesmo tanto que gastaria num subaru pra colocar no buggy, mas nao vai ter tanta adapatação assim, o peso do vw é bem menor e é a ar (nao usar o odiado radidor d`agua) mesmo com peças especiais que são caras, nao devem passar o preço das do subaru. Acredito que a vantagem seria só por estética mesmo, logico que o 6cil e o turbo teriam mais cv que o boxer preparado, mass....
É que nem colocar o motor do corvair, um p.. de um motor lindo, mas nao tem um custo beneficio tão bom assim. Só vale se o tanto de potencia requeria é absurdamente alta ou se quer deixar bonito apenas.
flw
flw
Pontos : 5642
Eu também não tenho a mínima vontade de trocar meu velho e bom boxer por nenhum outro motor mas como sempre aqui vejo gente interessado em substituir o boxer por ap ou outros mais potentes então criei esse tópico pra que esses tenham mais uma opção de escolha.GTMartini escreveu:Fico na duvida, sei que o motor do subaru é bem melhor, mais moderno, mais economico, maissilencio etc.... Mas será que não vale mais a pena trabalhar num vw ar mesmo? Gastando o mesmo tanto que gastaria num subaru pra colocar no buggy, mas nao vai ter tanta adapatação assim, o peso do vw é bem menor e é a ar (nao usar o odiado radidor d`agua) mesmo com peças especiais que são caras, nao devem passar o preço das do subaru. Acredito que a vantagem seria só por estética mesmo, logico que o 6cil e o turbo teriam mais cv que o boxer preparado, mass....
flw
Pontos : 11775
Aqui tem um video de um fusca com boxer subaru.
https://www.youtube.com/watch?v=DwS3W227qP8&feature=related
Pontos : 10798
que tal um 8 cilindros??????????
<script src='http://img88.imageshack.us/shareable/?i=jamaro5g.jpg&p=tl' type='text/javascript'></script><noscript></noscript>
Última edição por Daniel Sul em Seg Abr 04, 2011 8:06 pm, editado 1 vez(es)
Tá parecido com o do CHICO BIELA.
Pontos : 10798
Tô enganado, ou são dois motores boxer VW unidosDaniel Sul escreveu:
Pontos : 7598
É isso mesmo Volnei, no caso aí um 8 cilindros a ar já em fase de acabamento da montagem ...
jP, vi no fotolog do Chico que ele fez motores de 2, 6 e 8 cilindros usando a mesma técnica ... achei interessante mas gostaria de ver pronto e funcionando!!
Eu fiquei curioso pra saber como ele vai fazer pra esse distribuidor de fusca mandar corrente para as 8 velas.Volnei S escreveu:Tô enganado, ou são dois motores boxer VW unidosDaniel Sul escreveu:
Pontos : 11775
Como será a união dos virabrequins ou será um único.
A criatividade não tem limites.
Se alguém tiver mais informações sobre aplicação e potência, fiquei curioso.
Pontos : 7598
Volnei S escreveu:Como será a união dos virabrequins ou será um único.
Volnei há a necessidade do uso de 2 viras para se fazer um, ok?!
Vale a pena ler este topico
http://www.forumfuscabrasil.com/index.php/topic,15576.30.html
Por esse ângulo da foto quase não percebemos diferença entre o motor Boxer VW, motor boxer 6 cc subaru, e o motor enertron 2 cc.
http://www.gurgel800.com.br/imagens/enertron.gif
Pontos : 11775
Para quem quer se aventurar, aqui está o link de um vendedor de flange subaru para o cambio do motor boxer;
http://www.lfacil.com.br/detalhes.asp?lojaid=19&departamento=164&categoria=337&produto=10397
Pontos : 9925
Suabaru no Fusca no Buggy deve ser a mesma coisa
Video 1
Video 2
Video 1
Video 2
Woodboy- Doido por areia!!!!
- Número de Mensagens : 97
Pontos : 4346
Outro video, Fuscaru
Pontos : 4346
seraaaa que daria pra pegar o cabeçote comandos e afins para adaptar no boxer da volks? pra tirar o barulinho?
Pontos : 6883
Mad Well escreveu:seraaaa que daria pra pegar o cabeçote comandos e afins para adaptar no boxer da volks? pra tirar o barulinho?
Não faço a menor idéia, mas o "barulinho" do subaru é bonito mesmo.
E o sistema flame vc já instalou?
Pontos : 4346
» Blocos, Cilindros, Camisas das diferentes versões do boxer
» Motor boxer
» Motor boxer
» NUMERAÇÃO DOS MOTORES BOXER
» Motor 1600 aspirado
» Motor boxer
» Motor boxer
